gear ratios to tire size questions | Ford Explorer Forums
1993fordexplode
Littleton NH
1994 sport 1993 xlt
my sport has 3.27's what is the biggest tire i can run without killing my clutch or is it worth just swapping the gears from my 93 xlt with 3.73's i plan to run 34 to 35 inch tires
for 34's or 35's ur gunan want somthing lower than 3:73
ill psot a chart in just a min with tire to ratios
PEACE
With that size tire you're gonna want 4.56 gears. 4.10s would work but are on the high gearing end. 4.88 will also work, but probably geared too low for your needs. Get 4.56's.
Definitely 4.56 for anything over 33 inch. my 4.10s are acceptable with my 33s but it is a close call.
i daily my explorer. and sometimes trail/mud with a few buddies on the weekends.
truck is a 5spd sport on 35x12.5.
will 4.88 be to low of a gear to daily on the hwy? no freeway as much but back road hwy's and such.
i keep hearing 4.56 and 4.88 but i need to figure out which one.
4.88 is a little deeper then stock gears/tires with 35s
iirc 4.56 would be a little under geared comparatively
you can still highway cruse with the 4.88s
