05dakotatrac
- April 12, 2012
- Ellsworth AFB, SD
- 05 sport trac 4X4
well i had access to dana 44's front and rear from a 76 waggy. well that deal fell through so I'm back on the hunt for now a dana 30 ease of 5X4.5 bolt pattern and comparable width and easier to find. i also have gears for the factory 35 and 8.8 in 4.56.
so my issue is if i re-gear, body lift, and roll on 33's and and do god only knows what to beef up the IFS (uniball upper joints, timken hubs, premium moog bottom ball joints, and figure out something for the piss poor CV axles)
or
roll into the headache of finding an axle and fabbing the mounts debate between linked (3 or 4), radius armed, or leafed. and then building the 30 to take the heat of up to 35" tires so chromoly, warn hubs, gears
honestly i know that either route has its downfalls. with the stock setup i keep the larger brakes, and all the parts are matching to one truck. the solid axle is more durable but the headache of custom almost everything and smaller brakes might be a fearful issue if anything goes bad and with all racked steering setups like tracs, 2nd gens, and newer models is customizing first and 2nd/trac racks to match.
i personally dont rock crawl or go hard core in my truck its mainly a DD and the occasional logger trails to the small ponds and lakes in the hills nothing my stock IFS wont take.just tired of the constant wear and tear items failing.
or
