My 2002 Explorer has a rattle in the rear end. I started with the obvious - something loose in the cargo area or under the 3rd seat. Nope. Then I went on to the less obvious - anyone who has done much suspension work knows there are some components that can cause a rattle that you hear but don't feel - sway bar links and strut mounts are particularly common culprits. Nope.
Finally I rode in the back while someone else drove, and the problem was obvious - the glass portion of my liftgate was moving around. Not at the hinge side (and I did indeed note how many threads there are about adjusting the hinges on the rear liftglass) but where it latches to the tailgate above the license plate.
So I popped the glass portion open and pulled the plastic trim panel off to the adjust the striker/latch relationship, and discovered that the only thing holding the glass closed is the wiper motor. It looks like there used to be a pair of studs welded onto the glass panel surround. Onto these studs went the u-shaped striker and then a thin sheet metal panel which holds the wiper motor, and the whole stackup was held together with rubber isolating washers and a pair of nuts.
On my Explorer, those studs are ripped off of the panel surround (or pulled/rotted through - can't really tell yet). The stackup is still being held together between the u-shaped striker and the nuts, so the glass will close and latch... just not very well.
Has anyone seen this before? If so, did you fix it by welding new studs to the glass surround or by removing the exterior trim panel ("applique") and putting a pair of flathead screws in from the outside?
thanks,
--Matt
thanks,
--Matt
