Christobal
- July 23, 2007
- SoCal
- 93 XLT, 03, 2 wheel drive
It is claimed to have burned the left front wheel bearing. That is a unit bearing correct? Cannot be test driven as normal, so if the wheel bearing 'burned' seriously enough to overheat that tire causing it to fail, what else will be in the crossfire.... Im thinking outer CV, the bearing, possibly the spindle itself and brake caliper due to seals overheating...says there's no brake fluid on the ground but wheel is still usuable, just needs new tire. Spare is on that corner now.
If I pick wheels up off the ground individually will that AWD system let me rotate each wheel independently?
If I do look, I will try to cold start....put it in gear, try to torque stall it a bit to make sure the trans/awd diff isn't loose or freewheeling. What else would you check for and consider?
Can these be run just rear or front wheel drive without issue? How difficult to disengage front drive by unbolting driveshaft etc.?
Thanks
Chris
Thanks
Chris
