- July 5, 2003
- Brockton, MA
- '93 XLT 4x4
If the T-case is engaging (lights indicate 4x4), but the front end doesn't feel like its locked then one or more hubs are most likely blown. If you are having T-Case engagement issues check out the 4x4 Trouble shooting thread.
The easiest way to test hubs (on vehicles with open diffs) while the vehicle is still on the ground:
To test for a blown Auto Hub;
1) Put T-case in 4x2 (disengage 4x4)
2) Crawl under the truck and rotate the axle shaft (any direction). After several revolutions the autohub should click and lock. If you can still rotate the axle shaft the hub is blown..
3) Repeat #2 on the opposite axle shaft..
To test for a blown manual Hub;
2) Lock in the Hubs
2) Crawl under the truck and try and rotate the axle shaft (any direction). If you can rotate the shaft the hub is blown..
2) Lock in the Hubs
