noruckus
- January 28, 2010
- Lexington, KY
- 2000 XLT, OHV
Well since the original post http://www.explorerforum.com/forums/showthread.php?t=276229 I've gone through a few things, 1st-original problem, truck complains a hole lot upon a cold start up, shakes, rattles and sputters for about 10 secs and then smooths out, changed the plugs and fuel filter, started great for 2 days, then back to the same at cold start up, cleaned the MAF and IAC, no better, replaced the IAC, non better. Truck then began to stall at idle with brake on, eg. at stop lights, or would stall and die when giving it gas to leave from stop lights. changed out fuel pump, great again for a couple of days, now wants to shake, rattle and sputter on cold starts again, oh, at fuel pump change replaced 2 vacuum hoses, I'm still pulling two codes P0155 O2 sensor heater circuit malfunction (bank 2 sensor 1) and P1151 Lack of HO2S-21 Switch, Sensor Indicates Lean, any good leads as to what I need to look at next and what parts I might need to replace, do I need to replace the entire vacuum system or? any help would be greatly appreciated.
Thanks guys. Mike
Thanks guys. Mike
