Plan carefully...
Eric,
Plan Carefully. Once you wonder far from the theme of what the Explorer/Mountaineer 302 is, the more you will need to go custom parts. Start by purchasing a Ford Racing Parts Catalog. There is a mountain of parts that will work with your vehicle without having to have custom pieces to make the aftermarket items work.
You have to keep in mind that GT40 & GT40-P heads have a slightly different bolt location on the exhaust ports than the earlier ('95 and older mustang) 302 heads. Ford moved the bolt holes up slightly on the exhaust port and the ports are more rounded.
Most aftermarket heads (AFR, Edelbrock, Dart, etc.) utilize the earlier bolt pattern.
If you absolutely must have aluminum heads, then Ford Racing makes a very nice GT40 "Turbo Swirl" aluminum head, P/N M-6049-Y303. They also make a GT40 EFI Intake manifold (M-6001-A50) and you can utilize the 1" spacer (M-9486-A53) between the upper and lower intake to give a little more of the ram induction effect of yor. With a wise choice of cam and Torque Monster Headers, you would probably be in the 350+ hp range easily, with just fuel injection.
If you opt for iron heads, stay with the GT40 heads you have. They're actually a very good head and work very well with the truck configuration of the Explorer/Mountaineer. The difference in performance between GT40 and GT40-P heads is nominal.
Here's a canned list of standard Ad-Ons I usually give people when they ask, "What else can I add besides Headers?"
Standard Add-Ons:
* 8 - Bosch Spark plugs, Platinum +4, PN 4458
* 8 - JBA Spark Plug (Ignition) Wires, PN 06239
* 2 - MSD, Ford Coil Pack, 4-Tower, PN 8241
* 1 - MSD Digital Dis-4 Plus, PN 62152
Your Choice on which way you want to go with your intake:
* K&N Air Filter replacement in stock system.
* K&N Air Filter cone element on end of stock system.
* MAC Air Intake replacement for entire stock unit.
* 16 - Ford Racing, Roller Rocker Arms, PN M-6564-B351
* 1 - Ford Racing, EFI Heat Spacer, 1" thick, Fits between upper and lower manifolds to help dissipate heat and significantly increase performance. PN M-9486-A53
* 1- Reprogram your computer/engine management system. Contact your favorite chip company or "bamachips.com" for your needs.
* Exhaust system from the CATs to the rear bumper. Your choice, many ways to do it. If you have more than 100,000 miles on the vehicle, replace the catalytic converters. Order from Ford.
All the items listed, along with Torque Monster Headers, should give you about 50-60 hp over stock without going into the internals of the motor.
Just a little food for thought. All the Best,
Bob Pasquale
Tech Performance & Engineering
