Heat, No Heat! | Ford Explorer Forums
Heat, No Heat!
albertabound
Calgary, Alberta, Canada
1996 XLS 4WD
:can: My heater seems to have a mind of it's own lately. It usually heats up nicely after a few minutes, and I'm good to go. Sometimes it will just blow cold air. It's totally random, happening at night, morning, after I've driven a while with the heat on, stopped, shut the engine off, then get back in a while later. All other functions are normal. It seems like a sticky sensor or thermostat. Has anyone had this problem, and/or know a fix? Thank you in advance.:)
Does the temp guage fluctuate more than normal? If so, maybe a bad T-stat.
i ve got the same problem the heat fluxuates i don t think it s a thermostat i think we have blend door problems possibly actuators
sounds like a blend door problem
