Heated seat not working | Ford Explorer Forums
chrystal
essex uk
2000 North Face
Drivers side dosnt work, the light comes on on the switch but no heat. What do I start to check?
Anyone - its the weekend and I feel like playing....well breaking something else!!
is the button on the seat?
My 97 seats have the button on the seat HOWEVER the buttom gets its power from a different source then the heater.
So first check the fuses then I would say unbolt the seat and have a look at the wiring.
if the button is on the seat then it should be pretty easy to find the problem, since there are like 3 wires that go to the entire seat.
If you have + and - where you should when you should (test with seat un bolted) then the heater istself may be FUBAR'ed
Yes the button is on the eat and is illuminated when I put the heated seat on - just no heat
fuse, then wiring under the seat and the plugs.
Hopefully its not the heater itself
