help! 1993 ford explorer gearing. 3.27 gears with 31x10.5 | Ford Explorer Forums
norcal925
California
1993 Ford Explorer Xlt
With 3.27 gears what is the biggest tires i can run without terrible change. I want to keep my mpg and acceleration somewhat the same. I just wanna be able to driver on the freeway still. If anyone could help itd be awesome. Maybe 30 inch tires? Just wanna make this work without regearing.
ive heard its terrible and you cant get on the HW ive heard its not bad. I just want a straight correct answer from someone first hand.
Not totally sure if i have 3.27's but in the case that i do. Im checking when i get out of school
Zac
The 235/7515's that come with your Explorer are about a 30" tire (29.5" I believe). With anything larger you will start to hurt in the acceleration department. I would go no higher than 31's, but some people have run 33's and higher without undue issues. Just remember that the larger the tire you have without compensating in the gearing department is going to be harder on your transmission. The A4LD isn't much of a transmission so if you decide to make the transition I would take steps to keep it running cool.
I wouldn't even think of bigger tires until you: know for sure that you have 3.27s, AND, have a budget set forth to get rid of them (the stock 235/75R15 (28.9") tires are already too big for 3.27 gears).
Have you checked to be sure you have 3:27s? If you do, go to the junk yard and get 3:73 or 4:10 out of a 2nd gen explorer. You'll get disks and a better gear ratio
If you find 4.10s in a junkyard you're freaking lucky. 3.73s, that's a different story.
I just figured it out and i have 3.73's with limited slip. What's the biggest i can go with those gears? Will 31's be good?
I have 3.73's im so happy haha, will 31's match up well with that gearing?
Thanks everyone for your help
31"s will be fine with that. Personally I wouldn't go up to 33's, however I've been told it'll be fine, but that's basically the limit for 3.73. It'll change your speedo a little bit, but not too bad.
Sweet thanks man, im planning on doing 31's mayne 32's will i have enough clearance with a 2 inch lift? Its the skyjacker 1.5-2 inch kit then im doing 2.5 in the back
PM your email and I'll send you a graph I made. It's for 2nd gen's but I think 1st gens have the same final drive ratio
Just checked, it's the same
I emailed ya
