JOHN223
- September 19, 2010
- NY
- '98 XLT AWD
Been searching around here trying to find out about replacement of the camshaft positioning sensor on my 98 5.0. Getting CEL error code P0304 and P1309. Before I take it in for a $$ diagnosis and repair I thought I can maybe change the sensor for $35. From what I can see the replacement involves two 7mm bolts and a 3 wire connector. Now, what I am confused about is that if the sensor is removed and replaced, does it throw off the timing? does it require the engine to be at TDC? Is the special alignment tool needed? Again, i will not go any further than the sensor at this point, not the entire shaft. Car is running fine though. Any info much appreciated! Thanks!
