toomanyfords
- October 2, 2011
- Rockville,MD
- 98,93,and 91 explorers
I know there are like 1000 different threads already on this but I have read them all and tried them all. My problem is I just finished rebuilding the top end of my motor (98 ohv), had a cracked head yada yada yada. While I was in there I figured I'd do a new power steering pump due to the excess whine and whatnot. So I get a ford pump from ford, install all went smoothly. Followed bleed procedures with belt off and rotating pully by hand, thought I got all the air out. Start it up and continue to try and bleed, no luck. Return pump and get another ford one (warranty) because I thought it was a bad pump. New pump is doing the same thing. Tried driving around locally, no luck still whines like a sumbitch. Tried applying vacuum to reservoir and tried that bleed process. Still whines although I did get a lot of aeration at first and continued vacuum bleeding until I'm not getting anymore. Still whines. Any opinions/advice would be much appreciated I need this truck back as the 93 I'm driving now has a cracked exhaust manifold and sounds like a firecracker. Thanks in advance, Joey
