- February 9, 1999
- Vail, Arizona
- 1992 XLT 4x4
I have a 1983 Chevy 1 Ton Flatbed that needs a new carb.
It currently has some unknown, falling apart, really bad shape edelbrock carb.
The truck has a 350 motor with a 4 speed transmission (its has granny and then 3 more gears) with no OD.
Rear end Ratio is 4:11
Tires are 31.7" tall (235x85xr16)
I was thinking of a Edelbrock 1406 Carburator which is I belive a 600CFM carb set to be lean to help with mileage
I want as good as mileage as I can get (I only drive at 60-65mph) but I need to be able to tow the explorer to the trails so I still need decent power and everywhere is freeway driving to get to.
At 65 mph my math tells me the truck will be turning 2800 rpms (Is that ok for a 350 ci motor?)
Also, If the wells go dry again, I will be carrying about 6000 lbs of water on the back of the truck (not flat ground).
If anyone has any ideas as to what I need, please let me know.. I "think" stock the truck came with a 700cfm quadrajunk
and I think a 500cfm won't be enough for that motor when I cruise down the freeway (or go up the hills).
Oh yea.. I was thinking edelbrock since the carbs are all < $300 and money is an issue.
~Mark
~Mark
