DeadRedex
- May 17, 2016
- Colorado
- 1994 Ford Explorer
Hello all,
New member but frequently visit the forum for advice and such. But now I need serious help.
(Edit) if you know of a thread related to this please kindly share, I hate to be the guy that has posted this for the 100th time.
My problems are sub par MPG, rough idle at start and sometimes hesitant acceleration from a stop then slowly gain life. But the big one is while I'm driving the truck will suddenly drop to idle rpm and I will have to release the gas pedal then quickly press it down again to regain cruising rpm/speed happens in spurts of 3's. The sudden rpm drop happens 10 mins in to my commute, seems to be triggered by bumps in the road and only seems to happen when the outside temp is below 50 degrees. So far I have cleaned the IAC and replaced the: thermostat, coil pack, MAF, TPS, fuel filter, fuel pump, fuel pressure regulator, fuel pump relay, spark plugs (not the wires) the battery, EGR and a sensor I can't remember for the life of me near the egr on the intake manifold toward the firewall.
The most recent replacement being the fuel pump. Tested pressure with key on engine off which revealed that the pressure dropped to 28psi. It didn't act as poorly, mind you this is the first 30+ mile trek with the new pump tonight and it took a much longer time for the symptoms to occur which is a plus but it's still happening.
I'd love to hook it up to see what codes come up but a squirel set up residence recently and damaged some wires which I will fix soon. The CEL did at one time come on every so often but haven't seen it some on in months.
