HELP from Arviat, NUNAVUT
bsuluk
Arviat, Nunavut, CANADA
1998 Ford Ranger XLT
My heater on the Ford Ranger doesn't force warm air. I tried fixing the blend door but is still blowing very cold winter air. Please help.
Tbars4
Moderator Emeritus
Elite In Memoriam
anaheim hills,california
95 ranger 4x4/ 91 X 4x4
...It may just be a case of a loose/missing vacuum line or, you could have a bad dash switch...I have seen this related more to the 95 rangers and 95 explorers though...:dunno:
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
Yeah I'd follow the heater lines up to the heater core and see if the lines are warm (after the engine has warmed up). If its not, then the problem is upstream of that. Like on my van, the electronic vacuum solenoid which controlled coolant flow needed to be replaced as it would not open.
bsuluk
No Warm Air
The hoses and the heater core are very hot, the fan switch works perfectly.
It's still blowing cold air through the defrost vents. I tried fixing the blend door as suggested. No luck. :mad:
