Wanted - Help needed with tire size. | Ford Explorer Forums - Serious Explorations
Wanted Help needed with tire size.
Parts or services wanted
Welcome To Explorer Forum! Why don't you post a picture of your truck so we can see your clearance... Are you saying it has a 3inch suspension and body lift or 3inches combining a body lift and suspension?
Here is a good list of sizes that have worked over the years:
91-94 explorers.
No lift- 31x10.50x15 on 15x8 inch or stock (15x7) rims
1-2 inch suspension lift- 31x10.50x15 - 32x11.50x15 on 15x8 rims/ may require some extensive fender trimming
2-3 inch suspension lift- 32x11.50x15 on 15x8 rims
3-4 inch suspension lift- 32x11.50x15 - 33x12.50x15 on 15x8 rims/ may require fender trimming
4-6 inch suspension lift- 33x12.50x15 - 35x12.50x15 on 15x8 rims/ may require fender trimming
2 inch body lift- 32x11.50x15 on 15x8 rims/ may require fender trimming
3 inch body lift- 33x12.50x15 on 15x8 rims/ may require fender trimming
2 inch body lift and 1-2 inch suspension lift- 32x11.50x15 - 33x12.50x15 on 15x8 rim/ may require fender trimming
2 inch body lift and 2-3 inch suspension lift- 33x12.50x15 on 15x8 inch rim
2 inch body lift and 4-6 inch suspension lift – 35x12.50x15 – 36x12.50x15 on 15x 8 rim/ may require fender trimming
3 inch body lift and 1-2 inch suspension lift – 32x11.50x15 – 33x12.50x15 on 15x8 rim/ may require fender trimming
3 inch body lift and 2-3 inch Suspension Lift – 33x12.50x15 – 35x12.50x15 on 15x8 rim
3 inch body lift and 4-6 inch Suspension lift – 35x12.50x15 – 36x12.50x15 on 15x8 inch rim
