frankcal
- March 9, 2010
- Perris, California
- 03 Sport XLT 3.73C, 5R55E
if no ones said it yet - always install the new races with new bearings. put the new races in the freezer for a few hours before installing them. it makes them easier to install. if you have a torch, you can also warm the hubs. you'll need 2 new cotter pins of the appropriate diameter (don't reuse your old ones). buy an assortment at AutoZone, or wherever, and you'll have a 10 year supply. they're cheap. I don't recall if anyone gave you instructions on greasing the new bearings before installation, but I like to put a glop of grease in the palm of my hand and drag the bearing through at a 45 degree angle until I see the grease get pushed out the other side. also put extra grease in the hub as it flows once it gets warm. when you tighten the axle nut, the torque (or preload) is very important. I tighten them down snug at first (to squeeze the excess grease out from between the bearing and the race) then spin the hub by hand, loosen the nut and just let the weight of the wrench tighten the nut + a tiny tweak. if you have to move the nut to get the cotter pin hole to line up, loosen the nut a hair it rather than tightening it. you can use an inch-pound torque wrench if you have one available, but unless you know it's correctly calibrated, I'd just rather do it by feel (this method has never let me down yet). also put a dab of grease in the inside lip of the seal, before installing the rotor on the axle, so it doesn't run dry at first.
I've been rereading the how to thread make by jstcruz on how to do em so i kinda have it memorized. But thanks for the tip on putting the races in the freezer. I had done that before when doing my ball joints and it worked like a charm so im expecting the same on this. Started getting parts in the mail so probably will be done early next week.
So when torquing them down they go to 35ft lbs at first rotated then backed off half a turn and just slightly tightened down? And is that it? I don't have an inch pound torque so i just want to make sure i get it right.
