Help Please!!!! | Page 2 | Ford Explorer Forums - Serious Explorations
Help Please!!!!
Just thought, have you checked your intake manifold bolts. I heard these have a tendency to loosen up and cause a leak.
New intake gasket was installed after problem started. Didn't get a chance to check for new codes. For the heck of it I am going to replace the fuel pump relay since it is the only fuel delivery part not replaced. Was also going to put on a new set of wires. Symptoms are Idle at 1000 used to idle at about 700. Stumble when you push the gas quickly. Smokes and smells like gas during cold idle. Still smells a bit rich when warm. idle speed goes up slightly by itself and takes about 15 seconds to come back down after coming to a stop. I am just guessing at this point but dose anyone think that a VSS could cause this? Maybe the ECU thinks the truck is moving not at idle?
I think you could test this by unplugging the VSS. I believe that the VSS only will generate a signal when the toothed ring inside trans or t-case moves past it, so this doesn't seem likely, but it should be easy to test. It may set a VSS code, but you can see the effect on idle if any.
Went to autozone to have someone pull codes but no one new how to work the tester but I bought a pressure guage and hooked it up quick. At idle pressure was 28. With vac line disconected shot up to 40. When i turned the engine off it droped to 20 and held. Pressure seems low to me. I guess I got a bad FPR?
Your 'key on, engine off' (KOEO) pressure should be 35-45 psi. Your 'engine running ' (ER) at idle pressure should be 30 - 45 psi, so it looks a little low. My book says it could be a clogged fuel filter, a bad fuel pump or a bad pressure regulator.
Ohh autozone.... typical typical autozone.
I'm gonna guess fuel filter or pump, not the regulator. Just a guess though.
Installed new regulator today. Presure at idle is 30 line vac line disconected 40. Pressure holds at 40 with engine off. When I first put new reg on key on engine off pressure was 20. turnned key off and back on again went up to 40. guess I should recheck since that dosen't sound right. I put my old TPS back on replaced the IAC motor with my old one took the computer conector off and reinstalled. It runs very good now. The idle is still a little high about 1000 but the idle dosen't rev by itself and lowers like it should. I will see how a cold start is in the morning. I think i still have a slight stumble but not nearly as bad as before. i think If I can eliminate that it will be perfect. At least it looks like there is light at the end of the tunnel.
Installed new coil the other day. I will check for codes as well as TPS voltage then check timing to make sure the PCM is working properly and go from there. Who would have thought that the new parts were no good. No i am worried about everything I put on from autozone. What untill I force them the give me my mony back for the **** parts they sold me.
Actually, that does sound right. My book says that idle pressure should be a little lower than engine off pressure. The book says 39 psi with engine off, key on. When you disconnect the vac line to the regulator, it is the same as wide open throttle which should be about 39 or 40 psi again. When you are at idle, the pressure is lowered by the amount of vacuum applied to the FPR, which gives about 30 psi.
The Solution
Stumped as to why I didn't get a code but the solution seems to be the ECT. To test I just pulled the connector off and the truck ran perfect. The solution was a $16 dollar part not that the other stuff didn't need to be done. The real test will be in the morning but I suspect the cold start will be fine and smoke will be gone. I will post again to let everyone know so hopefully this thread helps a few others. As of now it Fast Idles on a cold start at about 1800, steps down after about 30 sec to 1000, warms up drops to about 650 and idles perfect. No more stumble, gas smell or smoke so far. Thanks to everyone who helped.
What is the ECT?
Engine Coolent Temp
There are actually two different sensors on the Explorer - one is for the gage only - the other one feeds the temp to the PCM
Oh, duh, I was thinking electronic controlled something.
Is there anyway to test this, I am having some idling probs too, kinda rough and shaky. Cleaned MAF, IAC and checked TPS. It doesn't surge anymore, but it still is a little rough.
I get a TPS code, but sensor tests fine, varies voltage from 0.9 - 4.5 V, with no jumps.
ECT Chart
To test I just unpluged the connector. The one for the guage has a single wire, the one for the ECU has two. I believe it is just to the right of the thermostat. All smoke, idle, and rich symptoms are gone. the Truck runs perfect!!!!!
Glad you got it fixed! Woohoo!
So in the spirit of improvement, and to capture this for posterity, the question arises: How many of those parts that you replaced were really necessary, e.g. the coil? Do you suppose if you took the truck to Ford and paid them $80-plus for a diagnosis that they would have found the problem?
An example: When my '91 was doing this exact same problem, I took it to Ford and paid them $75 for a diagnosis. The concerns were (1) rough cold start, (2) raw fuel smell in exhaust, and (3) cruise control cutting out and stumbling at highway speeds. It took them two days to do the diagnosis so I had to rent a car for the two days ($120). So the total cost to me was a little over $200 just to find the problem. So I go to pick up the car and - they can't find the problem per se, so this is what they tell me they need to do to 'narrow down' the problem:
1) needs a major tuneup ($450) - they say they have to do this to eliminate unknowns
2) the 'tech' said that since my truck has so many miles on it (180k) that the oil pressure was low because the pump was worn, so worn pump means it won’t pump cold oil when cold starting the engine so the lifters won’t lift the intake valves all the way thus causing a rough cold start. Sounded like horse sh*t to me at the time but, having no other data or any way to disprove that at the time, I went with it. I asked him if he checked the fuel pressure – he said yes and that it was fine.
3) He couldn’t verify the cruise problem but said the only thing it could possibly be would be addressed by replacing the cruise servo ($350).
So the total repairs were over $800. I said fine, thanks, and took the truck home and posted my problem on this board. Dr. Alex said it sounded just like the FPR so I replaced it and – the truck runs perfectly. No more cruise stumble, either. Hmmmm…
The point here is that, had you taken your truck to Ford and paid for a diagnosis, they MIGHT have found it. In my case they didn’t, I would have paid over $800 for unnecessary repairs and I STILL would have the same concern! You did the diagnosis yourself and finally found the problem through a strategy of combined R&R, trial and error, and diagnostic testing. I am thinking it is likely you replaced some perfectly good parts during this time, but maybe not. And you had the use of the truck during this time and you didn’t have to fart around with rentals, getting rides, etc., having to put up with the dealer’s ‘tude, and all the other inconvenience.
It just astounds me how these techs are continuously unable to diagnose driveability problems even with a bay full of diagnostic equipment and years of experience. Sheesh.
Yeah, the way I see it, you can replace 3 parts for every 1 part the dealer replaces. By the time you pay diagnostic, part markup and install, it doesn't hurt to try a few things.
You may end installing some uneccessary parts along the way, but hey, you got new parts, rather than paying some guy who may or may not have been able to diagnose it anyway.
The good news is next time I have a problem I have good parts to try so it will cost very little to find the solution. I replaced just about every sensor on the truck all at once + it runs like new. I suspect that since all the parts were original and have a 250000 miles on them they would have been on there way out soon anyway.
