mawrazen
- June 10, 2007
- Atlanta, Ga
- 94 Eddie Bauer
The sucking noise is your problem! Your losing vacuum!
If you hear a sucking noise that is where the vacuum is leaking from.
Track it down and reconnect the hose or replace it if it is cracked. The tree has a couple of extra ports you will want a plug on 1 or 2 of them. The leak could also be caused by a loose hose that has fallen off. You will want to look around the engine compartment to find the source of the SUCKING Sound and reconnect the hose in question.
Hope this helps?
You can do it!
Hope this helps?
You can do it!
