Wow.. looks like the frame rails got a little tweaked. How are you gonna straighten those? Looks good though!
only the drivers side.... i believe they call it the horn?? its not to bad and looks worse in the picture then it really is. I am going to put a little pressure on it and heat it up. Then i have to see if i can buy just the frame ends where the bumper bolts on and weld them on- if not off to the machine shop and ill make some new ones along with the brackets for my body lift.
You can buy the bumper horns from Ford. Cut off the old one weld on the new one. Cake.
Looks like your aprons ( side panels ) are gonna need a little tlc.
Looks good man, you are comming along just fine.
Great idea to show some love to the front of your engine. As long as you have it all apart you might as well.
what exact measurements should i be taking? and where? any tips would be great!!!
So far I have everything around where it should be. I have to start taking exact measurements like above and get everything perfect. I have to wait and pick up the body mount wednesday also.
