tonsofguns
- February 9, 2024
- Knoxville, TN
- 2005 Explorert XLT 4x4
I was given an 05 explorer XLT that needs some work. The usual suspects. Abs/advtrac lights. Water pump. AC actuator. Vent control plastic piece is broken. Etc
I had the ABS codes read today. No solution from AutoZone. Not finding much information on an actual fix though. I'm going to clean the sensors tomorrow and see if that solves anything before I replace the sensor cluster.
Anyone deal with these specific codes?
Also have a tpms fault on the dash. That didn't pop up when they read the codes though
C2777-E0 sensor cluster bus failure
C1963-20 stability control inhibit warning
