Help with lift kit decisions. | Page 2 | Ford Explorer Forums
oh ok man wow this has really helped me a ton. and yeah i plan on letting a shop do my gears for me and i might go with a superlift i think or skyjacker if i can get a good price after i get my heads back on and anybody know where to get replacement push rod lifters? and do i need to do anything special to put them in place. i need 2.
I need some help too.
I'm interested in lifting my 1993 Explorer, I'm looking at buying a 4" suspension lift and a 3" body lift from suspensionconnection.com the only thing I am not sure about is what else I need to get, I've heard that I need to buy a steering extension and fuel line extension, or something along that line. I have the links to the items I want to put on my truck but I'm not sure what I need and I want to buy everything I need to make this work at one time not 20 different times.
http://www.suspensionconnection.com/cgi-bin/suscon/793.html (Body)
http://www.suspensionconnection.com/cgi-bin/suscon/248504.html(Susp)
Also I would like to know if I will have to change any gear ratios, so I don't screw over my transmission, I want to run either 32's or 33's.
Thanks for the input, Tim
Timsbigbike@aol.com
Timsbigbike@aol.com
Dude... your question has been answered 10000000000000000000000000 times on this forum. SEARCH...there's a search bar right at the top. Do a little of your own research. Yes you need some extensions, yes you should regear, yes it's expensive.
hey anyone know what if theres any other lift kits for the 99 explorer?
iv only founda 4 inch lift and i only looking for a a 2 to 2.5 inch lift
not looking at gettin bigger tires just looking some extra clearnc....
breaks on my explorer
does any body know why breaks on explorers always go out? i was thinking it was because my exhaust manifold recently became very rusty. or perhaps its because my twin turbo is causing my shocks not to have proper bouncing ability. Does any body know if my cherry bomb could affectt the way my pistons rotate around my wheel barrings? And one last thought.... maybe my breaks are going out because i put rain-x in my big block. Thanks alot for youre help. :salute::rangerred:
ok some one ignore that my girlfriend put that there wooow.
