help with lift! | Page 2 | Ford Explorer Forums
help with lift!
I can't really give you a definite answer because I can't look at it. But, if I had to guess, it looks like those are adjustable shims to correct camber on the TTB suspension, which should work for your Explorer. But the only real definite answer I can give you is for the shims on RockAuto.com, which I know will work.
35's will not fit under a 5.5" lift without fiberglass, you will need a 7" lift to clear 35's
go with a superlift 5.5, screw a body lift go with coil spacers up front and warrior shackles in the back, i have a buddy that did this n i helped him with it and he is runnin 35x12.5's BFG Mud Terrains and ther is no rubbing and it is a 91 just like mine. thats if you are only goin for looks tho like he is. For me that wouldn't work cuz i am ruff on my truck, and that lift would rub on 35's. If u plan on bushing with it then go to http://www.jackit.com and look under skyjacker, they sell 8 inch coils, 8 inch pivot drop brackets, 8 inch radius arm brackets and dropped pitman arm to fit. it would run you around 700 with out shocks but those ain't much.
Who said they would?
I'll say they will. I give you BKennedy's 5.5" Superlift with no glass and no body lift with 35s.
That's a good lookin truck. I'm guessin he trmmed some? Are those 15x10's or 15x8's?
15x8 w/3.75 backspacing. You can see some trimming and rolled edge on the rear of the front fender. That's how mine looked beofre I got the glass. Paul Bredehoft had the same set up as Brian (actually Brian got the Superlift from Paul)
wheeling94x if you want 35s get them and a 5.5"lift and make them fit. :)
Hey Fenderguy, how's your flexing for offroading, does it rub at all?? My buddy's did just a little so that's y he stopped bushin with his.
For having a 4" lift with stock Radius arms and 35s it didn't do too bad flexing. Mine only rubbed the back tires on the inner wells like everyone else. I didn't rub the front at all.
wow i never saw a explorer with only 5.5" of lift and 35's with out fiberglass
