moneymgk
- September 3, 2025
- Location
- MD
- Clinton, MD
- 2018 PIU
I purchased my 2018 PIU from an auction on Saturday and picked it up later that day to try and start sourcing parts since all 4 doors were damaged as well as the lift gate and bumper. From reading online I found that most parts are interchangeable with some needing to be fixed in FORscan.
I purchased 4 doors and a lift gate off a 2018 Explorer Sport from a junkyard and got them all fitted. The problem is the window switches on the driver door no longer works. The door lock buttons and power mirror buttons also don't work. Both rear window switches on the rear doors work and will put the windows up and down. The front passenger window also works.
The power lift gate doesn't activate either but I believe that could be due to the original lift gate not being power. I believe that would be fixed with the lift gate control module and possible FORscan enabling. There is also no fuse in the power lift gate spot but I swapped one from the power seat but no change. I'm waiting for the OBD link cable to arrive to check things out.
I disconnected the battery and reconnected and nothing changes. Am I missing something else with the doors and lift gate?
Appreciate any and all help/advice...
