Yeah, he is using the one way fob....programs the same. Visit accessories.ford.com
I found very specific instructions finally:
Here are the instructions for the long range remote start fob programming for 11-15 Explorer:
Key Start Vehicles:
NOTE: These steps must be performed with the VSS module security jumper removed if previously installed. For additional information refer to "VSS Module - Optional Vehicle Security Features".
1 Start with doors unlocked
2 Driver's door open (remaining open throughout)
3 Verify that the gearshift lever is in the "PARK" position.
4 Depress and hold brake pedal.
5 Start with ignition key OFF.
6 Cycle ignition key to the ON then OFF position 5 times, then back to the ON position a 6th time. ▪ The horn will honk 3 times to indicate transmitter learn mode access.
7 Press the START button on each transmitter you wish to program. The horn will honk 1 time each time the START button is pressed to indicated the transmitter has been learned.
8 Cycle ignition key to the OFF position to exit transmitter learn mode.
9 NOTE: If the security jumper is installed the vehicle security features are disabled. If previously removed, reinstall the VSS module security jumper. For additional information, refer to "VSS Module - Optional Vehicle Security Features".
Push Button Start Vehicles:
1 Enter the vehicle with the vehicle key(s) and key fobs you wish to program.
2 Depress and hold brake pedal.
3 Press the start/stop button.
4 After the vehicle starts press the start/stop button to shut down.
5 Repeat steps 3 and 4 an additional four times, ending in ignition off, engine off.
6 Release the brake pedal.
7 Press the vehicle start/stop button twice to turn ignition on. ▪ The horn will honk 3 times to indicate transmitter learn mode access.
8 Press the remote start button on each fob you wish to program (horn will honk indicating successful programming).
9 Cycle ignition to the OFF position to exit transmitter learn mode.
10 NOTE: If the security jumper is installed the vehicle security features are disabled. If previously removed, reinstall the VSS module security jumper. For additional information, refer to "VSS Module - Optional Vehicle Security Features".
