Help with replacing shift solenoids | Ford Explorer Forums
cvacc411
Port St. Lucie, FL
92 XLT
2001 explorer sport 4wd, 5r55e. I was able to change the eps, tcc, and the two shift solenoids on the one side. When I tried to change the two shift solenoids on the other side, one of the solenoids does not want to stay in place and feels like it is being pushed out, I beleive it is SSC. Is this normal?
First, check the transmission forum. That's where this thread should be. Next, read the stickies there. That's where your answer should be. Finally, search. There will be more threads than you can imagine on this subject. Then, after all that, if you still have questions, come ask us again.
