steelninja187
- April 18, 2007
- Lexington, KY
- 1991 XLT 4X4
Ok, my 1991 XLT 4X4 was running like poop. Sputtering and dying at low RPM's. So I've changed the fuel filter(extremely clogged), checked the catalytic converter(also clogged), cleaned it out since there aren't any o2 sensors after the cat, installed a cold air intake, flowmaster muffler, already checked the MAF, replaced the fuel presure regulator, fuel pressure was good, ran good for about a week after this stuff then went back to sputtering and dying, so I changed fuel filters again (partially clogged after only a week!?!?) I added new Bosch Platinum +4 plugs with OEM motorcraft 8mm plug wires to the list, and now the throttle is really sluggish when you hammer the pedal, idles great though, smells like it's running rich all the time, but smells like gas is literally dripping out the pipe when you throw the fuel to it. Mechanic says the o2 sensors are sending a very weak signal. Should I go ahead and replace those too? Possibly the fuel pump or relay. I'm lost and out a few dollars at this point. Any ideas?
