Do you have a multimeter or a logic probe or test light?
If you were to unplug the blue/red small gauge wire (just pushes on) from the fender mounted solenoid what happens when you turn on the key? If your starter doesn't engage, your problem is between the end of that wire and your ignition switch.
If this is the case, I would check to see if there is power in the starter wire coming from the ignition switch when the key is in the run position. Probe the heavier gauge red/light blue wire in the bundle of wires coming from the ignition switch (couple yellows, black/green, grey/yellow, red/light green). You have to remove the plastic from the bottom of the steering column. If you are getting +12 volts when you turn the key to run, it is the ignition switch. Not the key cylinder, that only turns the switch.
Have a look and let me know how you made out.
