High brake light flickering, how fix? | Ford Explorer Forums
Knotdun
Rockville Maryland
96 XLT
High brake light (the one up high on the rear window), flickers all the time, not just when brake pedal is pushed.
Would like to change-out the switch. Is it located behind the brake pedal lever under the dash?
Yup, right behind the brake pedal. Sounds like you may have a short in your switch. Should only take you like 10 minutes to replace. 2 wires and some screws. If it only flickered when you pushed the brakes, then I would say it was your light bulb holder in the light itself, but you say it does it on its own with no pushy pushy on the pedal. So I agree, got to be the switch. Probably not a very expensive part. just a small pressure switch.
Good luck.
If you need anymore help on anything, this is the place to be. The search option will help a lot too. Millions of words here about the explorer.
Welcome to the sight, and again, good luck.
Andy
