hole in differential from lift kit | Ford Explorer Forums
gingell15
martinsburg,wv
1992 ford explorer
got a 4" trailmaster susp. the drop bracket busted a hole in muy differential,what is a easy way to fix this problem, is there some kind of different braket i can throw on there without changing everything else.:navajo:
That happened to my old Explorer. All I did was grind down the corner of that bracket and it took care of the problem. That way you don't have to worry about getting anything else.
