your not asking that b/c i said "geez, $40 a pop, you coulda thrown some rancho's on there for that price" are you?? if so, there are no rancho support shocks, i was just kidding around saying that they are almost as much as rancho's, so he should just buy them and stick them under the hood.
My hood supports are still holding strong but my liftgate supports will need replacing soon. I noticed that the stock support is sort of riveted to the body, any solutions for replacement?
been using the stick method for over a year now. works great!!! i even put a nail in it do hang a light on since ours didn't come with the little hood light. total cost = $0.00
I just got some from auto zone, one of them was already broken ah!! and the only way I could possibly get them to fit was to take a hammer to them which would just shatter them anyway.(yes I did try to install the opposite way the normal shocks are)
Originally posted by Hartman My hood supports are still holding strong but my liftgate supports will need replacing soon. I noticed that the stock support is sort of riveted to the body, any solutions for replacement?
Unless yours has been modified from original, the rears are the same as the fronts, just bigger. Its pretty standard for a gas spring, it has a ball and socket joint on each end. The ball is on a bracket which is spot welded to the hatch and the body. The socket is held in place by a metal clip which you pry out. There are grooves in the end that allow you to remove it without completely prying it out on the hood supports, I think the hatch is the same. The clips are painted black, so they are harder to see.
I've had a rear window shock break before too. the little eye loop broke right in half. Luckily I was still able to stick the now "U" end support into the spot and it worked fine. I rarely used my rear window anyways and the pressure from the shock held it in place. I think I may also have to replace the door shocks soon. It stays up, but has a hard time coming out of the compressed position. Do they make Ranchos for these too?!
I was not too impressed with the autozone hood supports. I replaced three of them in five weeks. They are plastic on the ends and break when you close the hood. I just ordered some from FPN for $40.00 a pair, and should be here by Friday. Sometimes buying Ford OEM is your best bet.
I have the same kind that napa sells but got them from Autovalue parts store. $25 for the set. No problems yet after a little over a month. Major improvement.
