hondakillah
- September 26, 2010
- Washington State
- 1994 Limited
I have a Bronco II, lifted 6 inches with an 8.8" axle installed on it. When building the axle, I had to remove the stock sway bar mounting points to make space for the new spring perches for the B2. I haven't found replacement perches yet, so the B2 doesn't have a rear sway bar on it, which gives the vehicle plenty of roll. For driving the vehicle, it's easy enough to just take my time, it's not a sports car. But, I have to transport this car across the country soon, and I would like to make sure that it doesn't get hit with a cross wind that throws off the total control of the trailer it will be on. The plan is to strap down the axles to the car trailer, and keep the suspension flexible. The vehicle will be loaded up with stuff to be transported with it. I was wondering if there was a simple enough way to add limiting straps or maybe "tree-savers" D-linked onto the vehicle to help control the roll of the body of the vehicle while on the trailer, while not inhibiting the flow of the suspension overall.
Thank you for your help.
