BonesDT
- July 12, 2002
- Westchester, NY
- Red '99 Sport SOHC 4x4
I need help with this. My P-Brake has been broken for years and I have a manual transmission. I just replaced the p-brake shoes, hardware and all cables, which were rusted up and seized over the idle years. It now works, but not perfectly, I wouldn't trust it alone on a hill.
I took some measurements and I have a clearer idea of what's still wrong. My drawing shows the measurements I took, but to simplify things, when I press the the p-brake pedal down 1.4", the left wheel cable is pulling 1.0" while the right wheel cable is only pulling 0.4". So the cables aren't being properly equalized. So the right cable is harder to pull than the left cable. Like I said, both cables are brand new Raybestos'.
So the left wheel works perfectly. It releases completely and then tightens up. However the right wheel p-brake shoes open and close very slightly, so I had to adjust the shoe adjuster, but basically, the shoes slightly rub when the p-brake is off while I'm driving, then when I apply the p-brake it doesn't tighten as much as the left wheel.
Now here's the question: how the hell do you fix this??
