How do you remove third brake light? | Ford Explorer Forums
sfgmen415
CA
92 navajo
Like most 1st gens out there my third brake light bulb is out and I don't know how to take off the cover
I believe that there is two screws on the outside cover, then pop it off and you have axcess to the bulbs. Did mine last year, all I know is that it was easy.
i tried that, but i couldn't get it off. does just the red part come off or the the black part to.
with a BIG hammer
try to unscrew in than lightly try to pry it off without breaking it
DO NOT try to pry the red part off. The whole thing will crack. Ask me how I know? :)
The entire thing with the black against the truck comes out. It can be a PITA. Unscrew it, put a towel over it & with a hammer tap the sides. It should free up some & then take something to put under the light & pry it off.
Here's how it comes off on a 93-97.
Spare one
Mine has a crack in it, any9one have a spare one cheap ?
Thanks
Dwight
I think they're looking for an Explorer light...
My bad guys I thought this was a Ranger thread on the board.:confused:
two screws then lift out the bottom ( closest to the window) as you pull it out. The assembly is tucked in there pretty good.
My '91 worked fine but a '94 I recently played with was a mess, I ended up hard wiring the bulbs in place.
