knightpitt
- November 17, 2005
- Pgh, PA
- nada
I've localized an issue with my '94 4x4 Ex to the front passenger side spindle bearing. So, last night, I tried to remove the spindle piece.
First off, the ABS sensor was in the way and the bolt holding it in was broken off well within the bolt hole, so I had to drill it out. No real biggie.
Once I got that off, I removed the 5 bolts holding the spindle in. Easy, cool. The Haynes manual says, "lightly tap the spindle with a soft-faced or rubber mallat to loosen, then remove the spindle."
Haha, yeah right! 2 hours later, after I pounded those little studs back through and spent at least 45 minutes on it with an air chisel, I gave up. I have no idea how to remove this spindle. There seems to be nothing holding it in aside from it's own sheer willpower. And, if it's willpower is that great, I have no idea how to get it off.
Any tips/suggestions???
Thanks in advance, guys!
