DaExplorer
- October 15, 2010
- San Diego Ca / Big Bear Ca
- 97 XLT SOHC 4x4
Does anyone know why I don't get any pictures??
Look at #73 of this post.
Ditto on thanks to DaExplorer for helpful pictures (thread 73). I have a 98 Moutaineer and had already revived my blend door function with the finishing nail through the actuator stem method about 2 years ago. That repair failed recently so I knew replacing the blend door was my only option left and I wasn't about to give Ford $2000 to do it. The pictures and text were a great guide and I was glad my actuator is the pop-out type rather than the bolt-in. So I first removed the glove box cover, then unplugged and removed the actuator. However, when squeezing myself in to look at the area to be cut (I'm a pretty slim guy) I had some doubts about being able to do this job. One post suggested removing the passenger seat but I decided to first try doing it with the seat pushed all the way back. To gain a little more room I took out the floor mat on the passenger side. I had ordered a pencil soldering iron that had a knife edge attachment to make the cut. To get in a "comfortable" working position I put an ottoman next to the running board with a couple of old foam pillows on top to support my body in the hip area and slid under on my left side. Referring often to the pictures I outlined the cutting area with a red magic marker. I used one of those small flashlights that band around your head for illumination but found it worked best just laying on the floor facing up.
The hot knife cutting worked somewhat but I found that it would partially re-seal the cut area as I progressed so I ended up starting the cut on each of the 3 sides with the hot knife and then cutting the rest of the way with a sawed-off hacksaw blade (about 6 inches long). Hint: when you get to the area where the bottom shaft of the blend door sits you will have to progress slowly until it allows the cut portion to bend down and away without breaking . I actually used the hot knife in this area going a little further at a time and the heat facilitated the material bending down to get the blend door out. Push up on the blend door and pull down on the cut flap and it will come out. Mine slipped out along with pieces of the shaft - it was broken at the top of the shaft as shown in the pictures.
Here's something important: Some of the smaller shaft pieces and alot of the cutting dust ends up in the socket that holds the bottom of the blend door shaft. I used plumbers grease on both a toothpick and on Q-tips to swab the area clean so the new blend door could turn freely. Once you get to the point where there is no more debris on the swab then put a dab of grease on your finger and force it into the shaft opening. This will give the new blend door a smoother "ride".
The new part is available at Napa and on the internet, including a few eBay sites. I paid $15 at Napa for a kit which includes other parts for doing this job differently (which looked to me to be more cumbersome.) There are different blend doors for various Ford models so make sure your model will accept what you are ordering. If you purchase locally from Napa bring the old part in with you to confirm the match.
For easy installation hold the new blend door at about the 2 oclock position as it will sit inside the plenum. Visually observe which way the actuator shaft will have to be set to line up and mate with the door. Then plug in the actuator (still not installed) and hold it facing front just as it will sit when put back in position. Then turn on ignition key and move temp control knob until the stem is in the same approximate position that the door will be in at that 2 oclock position.
Now unplug and re-install the actuator. Slide the new door up and in moving it around the 2 oclock postion. You will know it is in place when you feel it slide up slightly and you can't move it back and forth anymore. Hold it there so it won't slip out and push up on the bottom to slide it towards the greased socket in the cut flap. Once it drops into position use duct tape to hold it in position. Plug in the actuator. Turn on the ignition and rotate the temp control to confirm correct operation.
I had duct tape cut and ready near the work area - two one-inch strips about 4 inches long and I taped the flap in place on the right side. Take it for a drive and test the heat and air in all positions and satisfy yourself it is working properly.
I had bought epoxy for plastic at home depot (it's a putty that you knead and push in place) and covered the entire cut opening except the taped area and let it set for 24 hours. If you keep your hands and fingers wet it is easier to knead and you can roll it in strips to apply. Once applied you can smooth it out with a wet finger. The next day I covered the dried epoxied areas with black duct tape and it made for a nice neat job even though you can't even see it.
As I said I had serious doubts about trying this but the hardest thing was working in that confined area. Everything else went off without a hitch.
Does anyone have the jpg photo pics for Magicland's Blend Door procedure?
I am unable to view accompanying photos through this thread. Any help much appreciated.
Have the pictures been removed from this message? I signed on as a forum member, but still can't see them. The tutorial reads really clear, but it's pretty difficult to follow without the pics. July 2012 and people are still using it!
