how to clean fuel injector rail | Ford Explorer Forums
dagwood15t
wahiawa hawaii
95 explorer eddie baur 4d
hi im new to forums but i have a 97 mercury mountaineer with 5.0 v8
i keep getting a p0308 code which is #8 miss fire
i have new spark plugs, wires, and distro blocks
so the only thing i can think it would be is the injector
how can i clean it with out removing the intake manifold
i have a mityvac system but don't know where to plug it in to the fuel rail
any help would be great
thanks lee:salute:
The fuel supply and fuel return lines have connectors which are both in the front driver wheel well. :thumbsup: You should be able to see them right next to each other near the upper control arm to frame bolts.
do i disconnect both of them and then plug the return line or leave the return line on and run the cleaner threw the supply line with the fuel pump deactivated
