Ak LTD Xplorer
- December 17, 2003
- Anchorage Alaska
- 1996 LIMITED OFF ROAD 4X4
ok for as long as i have had my truck i have wanted to lift it with the ARC system..with some help from "atl" i figured out where the sesor for the ARC system is..it's only one sensor for all 4 bag's..the sensor look's like a small shock..you must unclip the sensor with a flat head screw driver.then ether compress it..this will lift the truck..if you pull on it the truck should lower..the way i plan on doing it is shiming the sensor with somtning to keep it compressed..one thing the truck will ride kinda bad with the bag's full...i don't know how it will ride if the bag's had less air in them..
here's the sensor(this if after i had the sensor un-clipped)
here's in 2wd
here it is with the lift
i am not responsable for any screwup's you may do to you arc/truck well trying to do this(i have to cover my ass)
here's in 2wd
