how to make ur side mirrors onto turn signals with puddle lights | Ford Explorer Forums
jtritz91
Menomonee Falls WI
05 XLT
Hey guys new here and wondering if it is possible to make the puddle lights into turn signals without having to change a bunch of stuff on it any help would be great thanks
I would assume you could do anything if you have the skills to think outside the box.
It has a bulb, just need to find an amber lens that would fit under the mirror, extend the bulb socket to sit outside of the mirror, then wire that bulb into the turn signal. with the right tools, some glue and some wire, i think it would be possible. might not be pretty initially but after some tweaks you could have a decent end result
May I ask why do you want to turn you puddle lamps into turn signals? Unless you do something to allow people to see really see them, they won't even notice them blinking(only at night, but BARELY).
Limited02 is right, only you would ever notice that, if you want mirror turn signals you could get the adhesive triangles with their own wiring harness at pepboys for under $20
Posted via Mobile Device
