jamesj
- June 26, 2009
- port alberni bc
- 2000 xlt
Okay so I have a 1991 ford explorer, When i bought the truck the 4x4 system did not work at all. After reading some great info posted here on the forums I was able to determine that the 4x4 shift motor was dead. I replaced the motor and lo and behold the 4x4 lights on the dash lit up. I thought for sure it was fixed. The truck shifts in and out of 4x4 correctly, I can hear the change in the t-case and also I was able to observe the front drive shaft engaging correctly. So I decided to go for a mountain drive and test her out. As soon as I got into some rough terrain i knew that something was not right. I slowly put the truck up against a small tree and gave it some gas only to see the rear wheels spinning and nothing from the front. So I know that the 4x4 is not correctly engaging the front wheels. I am new to 4x4 stuff and I have assumed that it is probably a problem with the hubs, does this sound right?
Currently the truck has the stock auto locking hubs. I am thinking they need to be replaced? Should I replace the auto hubs or convert them to manual?
Are the hubs the cause of my problem?
(Off topic) what size tires can I fit on the stock rims with no lift?
Please advise
thank you everyone
Please advise
thank you everyone
