sman83
- November 6, 2006
- Reno,NV
- 1999 Mountaineer
Getting a hum from the engine compartment, its intermittent, doesnt matter if its in park, neutral or drive.
I turn on the A/C and it magically stopped. I read some posts through the search and someone mentioned a A/C clutch issue and not a transmission problem.
Trying to get an idea if it is the A/C clutch vs. the trans *praying*
It is the original A/C compressor, clutch and its never needed a recharge.
Thank you mucho!
EDIT:
I ran some diagnostics on the Mounty with ScanXL and it indicated a A/C high pressure, whether that makes a difference, I couldnt say
Thank you mucho!
EDIT:
