usapadyra
- November 23, 2022
- Ukiah, CA
- 98 Ex XLT 4.0 SOHC 2WD
Hey there,
I have been having some intermittent electrical issues. It all happens at once and is caused by rain. In long spells of dry weather the problem is totally non-existent. After a rain spell it will come back until after a day or two of dry weather. Driving in dry weather speeds up the process of 'recovery'.
The issues are:
- no power windows
- no interior dome lights
- no wipers
- no rear defrost
After some reading around on here, I'm inclined to believe that the GEM is getting wet and that is causing the problem. Many report a leaking windshield as the root cause, where water is allowed to ingress and then drips down onto the GEM. I do not have any issues with water getting in through the top or sides, or at least, not that is visible. Headliner is dry, and I don't think I can actually see any water at the bottom of the windshield when inside the cab.
I have a tube of silicone to attack it with. My plan is to fill the top left and right corners where the windshield meets the roof, and also run a sealing bead right across the top.
I'm not sure what would be best for the bottom, however. Is it necessary to remove the wiper cowls and apply sealant right at the lower edge of the glass? I would love to simply take off the cowls and check it out, but I hear they are extremely fragile and easily broken what with those stupid clips. But I am prepared to take them off, if I must.
I was thinking I could put a line of sealant across where the glass meets the rubber trim just above the cowl, and then another line where the trim meets the cowl. My thinking is that this will force water to run all the way down and into the cowls themselves. At this point I figure the water is below the bottom line of the windshield and so can’t leak in.
Last time it rained I also noticed that the driver's side floor mat was quite wet, but I was also hopping in and out the car with wet shoes so it may have just been that...
What do you reckon? Am aware this is a total patch job.
Cheers
The issues are:
- no power windows
- no wipers
- no rear defrost
Cheers
