Triskal
- January 24, 2019
- 2008 Ford Explorer Ltd
I have a 2008 Explorer Limited 4.0V6, 5 speed auto, 4x4 with the factory class III hitch. I was towing a camper last fall on a hilly and windy stretch of highway and I had 2 instances of slippage where the engine revved up without any increase in speed. I believe both cases were while going up hill (I'm in the Midwest so these were mild hills). In each case I came to a stop as soon as I could and turned the engine off for a time. After that I got off the highway and used local slower speed roads the rest of the way and had no more issues. While camping I took it to a local transmission shop and he drove it a bit without the trailer but got no codes on his diagnostic tool. I also learned that I should have turned off overdrive in the conditions I was driving in.
That guy recommended against any kind of fluid flush or power flush and said it will likely need a transmission rebuild. After the weekend I was able to tow back home using local roads and leaving overdrive off and had no issues. When I got back home I talked with a local transmission shop (that everyone in town recommends) and just based on my description he said unequivocally that it needs a transmission rebuild.
This is our main daily driver and my wife and I have been driving around since then including through a snowy winter, some highway day trips, towing a couple small utility trailers around town, and I moved my camper before winter to its storage spot - again without using overdrive - all without issue.
So I am curious if any of you had any similar experience and what you did. Do you think the rebuild is inevitable or is there something less expensive you would recommend?
Please don't hit me over the head about towing with overdrive off - I've learned that lesson
Thanks
Thanks
