There are two "idler" pullies, one is up on top below the intake, the other is on the belt tensioner. There's not much to it, just take the belt off and remove the bolt in the center of the pulley to get it off (it goes counterclockwise like every other normal bolt). If you want to remove the whole tensioner and replace it as a unit (recommended if the pulley is bad on it, tensioner is probably not far behind) Take out the bolt in the center of the tensioner.
Deepening on the tightness of the bolt and the size of your arms, you might need to take out the fan and shroud to get to the tensioner. It's not hard either, just get the fan clutch wrench set from loan-a-tool at autozone or the like, and unscrew the fan and the two bolts at the top of the shroud. Take it all out together.
