Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
- Forums
- Generation Specific Forums
- 1991 - 1994 Explorer Ranger Navajo 1st Generation
- Modified 1991-1994 Explorers
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
I Wana see 1st gen ex lifted 4" and 33s!!
- Thread starter jrsbuck
- Start date
Add an avatar, upload photo attachments, and more!.
- January 28, 2000
- Huntington Beach, CA
- 1991 Eddie
Search around. There are a ton of pics of just about every mix of lift and tire size.
Here are mine, though.
4" w/33s
4" w/33s and glass up front
4" w/35s and glass up front
4" w35s and glass all around
4" w/33s
- February 9, 1999
- Vail, Arizona
- 1992 XLT 4x4
4" lift with cut front fenders on 33's
33x12.50r15 BFG KM2's just installed by maniak_az, on Flickr
~Mark
~Mark
- February 9, 1999
- Vail, Arizona
- 1992 XLT 4x4
Well, the one on our rig (blue rig) isn't exactly a good one. Its a $60 one we got through costco, made by Coleman. It originally just clamped to the factory cross bars. We have since made our own cross bars..
The metal on the coleman basket is really thin. I tried to weld through it and I couldn't get my welder (110v miller gmaw) low enough..
~Mark
~Mark
Southwcl
- August 14, 2011
- 1992 Ford Explorer 4x4
I can't find the place to put up a new discussion. I know it is supposed to be above all the other posts where I clicked this reply button but I don't see it. Anyone help me out here?
cloaked_chaos
- October 4, 2006
- Phoenix, Arizona
- 94 4x4 Limited
I know you are asking for 4" lifts, but since you said you were wondering whether or not to go bigger, this is either 5.5" or 6" (with 33x12.50 tires) not sure how much bigger though since I didn't measure the exact difference, and I'm not sure which brand it is. The explorer on the left is stock height.
jrsbuck25
- July 19, 2011
- Shamong, New Jersey
- 1993 explorer
I decided to go cheap as i can i got 2" coil spacers and 153 warrior for the back with a 2" body lift and try to fit 33s... i got the coil spacer and shackle in.. im doing the 2" body in shop tommorrow .... ill put a pic up wen its all done..... and any idea where i could get a heavy duty front and back bumper??
Bruces expo
- January 19, 2005
- Middle GA
- 91 Mazda Navajo
you can find the projectors on e-bay !
TXExploring
- January 2, 2023
- Galveston
- 1992 Explorer XLT
my old explorer. 4in and 33's.
Great looking rig. Were you able to put 35s with just a 4 in lift no other modifications? My son and I have a 1992 and are planning to do a 4in RC lift and trying to figure out what wheels and tires we can fit on it. Any help would be much appreciated. ThanksSearch around. There are a ton of pics of just about every mix of lift and tire size.
4" w/33s
TXExploring
- January 2, 2023
- Galveston
- 1992 Explorer XLT
I really like your old ride. Can I ask you how you added the recovery points on the front? I would like to do something similar to my 1992. Thanksmy old explorer. 4in and 33's.
- December 22, 2021
- Los Angeles, CA
- 1998 XLT 4x4
24 Rngr 4x4
as i recall it, significant trimming is needed. @BKennedy may know more. for a 4" usually many rhn 32/33 afaikGreat looking rig. Were you able to put 35s with just a 4 in lift no other modifications? My son and I have a 1992 and are planning to do a 4in RC lift and trying to figure out what wheels and tires we can fit on it. Any help would be much appreciated. Thanks
iirc i remember them being frame mounted on a different 1st gen before. there should be a hole kn the rail afaik and you add one more to bolt them on.I really like your old ride. Can I ask you how you added the recovery points on the front? I would like to do something similar to my 1992. Thanks
- November 29, 2000
- Location
- USA
- San Diego, PRofK
- 1994 XLT
I had 32's with a 4" lift and they rubbed. You will probably need a 5.5" lift for 35's and then still need to trim the back edge of the front fenders, and possibly knock the front edge of the rear fender wells forward a little. I had to trim the front fenders back to the first bolt in the bottom.
There are numerous posts and threads about what tires fit what generation Explorer with which lift, and how much trimming is required. Please use the search function, it works very well.
- December 22, 2021
- Los Angeles, CA
- 1998 XLT 4x4
24 Rngr 4x4
^^very knowledgable fellaI had 32's with a 4" lift and they rubbed. You will probably need a 5.5" lift for 35's and then still need to trim the back edge of the front fenders, and possibly knock the front edge of the rear fender wells forward a little. I had to trim the front fenders back to the first bolt in the bottom.
- November 29, 2000
- Location
- USA
- San Diego, PRofK
- 1994 XLT
Thanks. I've had a first gen since 1993, my current 1994 since 1995. It had its first lift a few months after I bought it, which was a Superlift 4".
- January 28, 2000
- 1991 Eddie
I put 35s on the same 4” Trailmaster lift but needed the front fiberglass fenders and hammered the pinch weld on the firewall. The back is just the 4” lift springs.
On the Rubicon.
On the Rubicon.
Similar threads
- Replies
- 17
- Views
- 12,626
