apex2012
- November 19, 2009
- Michigan
- 2001 Explorer Sport
I've looked through the forum before and found some possible solutions, which I have tried to no avail. I have a Ford Explorer Sport 2001 (4.0 SOHC), which I recently replaced the IAC. About a week after, I started receiving the "P1506 error code: Idle Air Contol Overspeed Error" and my idle is around 1400rpm (less when in gear). Here is what I have done to troubleshoot the problem:
1.) Unplugged the IAC, and let the vehicle idle
Result: Idle stayed between 500rpm - 700rpm while IAC was unplugged, but was very rough. When the IAC is plugged in, no rough idle at all, but idle stays high around 1400rpm.
2.) Cleaned the MFC (with MFC cleaner)
Result: No change
3.) Unplugged the battery for 30 minutes, let idle for 15 minutes after reconnecting
Result: No change in idle. Computer reset, but error code reappeared within one day
My next step is to replace the PCV valve (having difficulty finding it on this motor).
I figure it would be fair to mention something I feel may have contributed to this problem. A week or two before my IAC completely died (tried cleaning, no go), I washed the inside of the engine compartment. I'm not sure if this contributed to the death of the IAC, but I figure it may very well contribute to the rough idling when the IAC is unplugged. Also, I checked and I am not getting any misfires.
Any help would be much appreciated.
Result: No change
