myexpl
- December 16, 2011
- 1996 Ford Explorer
I am new in this forum. I have 1996 Eddie Bauer 5.0L 8Cyl engine AWD Explorer. It is excellent condition and is about 100K miles. Two weeks ago, engine suddenly coughed up and check engine light started flashing. I knew that it was misfiring. According to manual, SUV had spurk plugs that need no replacement until 100K mile. I took the car to a freindly shop (I use them often) and they told me that scanner showed that cyl. 7 and 4 misfired and it was time for the tuneup. I asked again high performance spark plugs replacement. They installed that iridium spark plugs costing each almost $14. I got the car back and started noticing next day that in idle speed there is an annoying sputter and slight jerk . I asked the guy. He said he did not change the fuel filter. I got an original mopar fuel fileter and he installed last Monday. It did not make any difference. He tells me that the engine is getting aged. He also claims that it could be dirty fuel injectors. He said, he can clean them up with a special machine that uses a special detergent to get rid off the carbon residues in combustion chambers. He is asking $130 for that.
I looked through the internet, some claims that this could be the Idle Air Control valve issue. They would get dirty as well. Some suggests that it could be wrong spark plug replacement too. If it is a wrong spark plug installlation (I am not so sure the mechanic could be that stupid doing such a thing. BTW, he also changed the spark plug wires when he did the tune up), then I should have a problem when I am speeding as well, Right? I am confused. I saw some articles about bad air hoses with cracks causing such thing. Can anyone help me by giving a hint rather than shooting in the dark with this mechanic? They were good and a reasonable place. That is why i choose to let my car handled by them.
Thanks!
Thanks!
