Well it's like this, I have a vibration that seems to be coming from the RT. front of my truck. It's a constant humming/vibration that when I turn slightly to the left seems to disappear?
I had a similar problem with mine a while back. Whenever I would veer a certain direction the right front of my explorer would hum and vibrate. It took me a while because I thought the right wheel bearing was bad since the noise was coming from the right side but it turns out that it was actually the wheel bearing on the left side. You might want to start by checking the bearings.
Wheel bearings would be the first thing to check. If they're ok, try rotating the tires to see if the noise goes with the tire. Sometimes if tires wear unevenly, they will whine or howl..
