410explorer
- December 11, 2023
- Annapolis maryland
- 96 explorer xlt 4.0
So heres the deal i have a 96 explorer 4.0 with 197kmiles i never had a key fob since iv owned the truck a few days ago it was parked and a alarm started going off even though i didnt even know it had one then about two days ago i went to start tge truck but the battery was dead i jumped it got it running then my voktage climbed all the way to high and the battery light came on i ordered a new altenator but it took 3 days to get here and i had to still get nack and forth to work so then on day 2 it realky stared acting crazy windows stopped working licks woukd intermittenly work the tge compass dispmay started blinking and the truck shut down i had to have it towed the battery was fr i ed i brought a new battery and webt to start the truck but no fuel pressure so i figure ok welk i need a fuel pump i replaced fuel pump with no luck i realized i coukdnt hear it cone on with they key but if i jumped the relay terminals the pump woukd run but truck not start no spark so i checked around both fuse boxes i had power to all fuses but one under the hood the air bag fuse was blown and one in the truck the GEM fuse i reokaced both the gem fuse kept popping i jumped it with a wire and then GEM started to smoke obviously has internal short so i ordered a new one but i also realized when i turn the key to on i have no check engine light does this mean the pcm fried ? I cant see anyother readon theres power at distrubution box but no spark or fuel pressure unless the pcm just not asking for it
