Install 2001 single ford cd player in 97 f150 | Ford Explorer Forums
SteFin
nashville tn
99 Explorer
I buy wrecked Explorers & Engine/Trans dead Explorers and F150's. I got a couple of 2001 nice stock single CD players, I want to install in my F150. The F150 aftermarket stereo is going out, and has an aftermarket wiring job. Anyone every done this or seen this movie. I've got the Explorer wiring diagram in a Chilton's manual but not the F-150. I've got two wiring harnesses in the wrecked 2001 Sports (so I can cut the connector plugs that plugs into the stock Radio/CD player) The F-150 has a 12 pin single connector that is splice into two more connectors the 2001 has 2 plugs with well over 20 pins. Thanks SteFin JunkYard Dog ShadeTree any help will be appreciated.
It will work if your truck has an amp in the headunit. But seeing that you have an aftermarket radio in it already, you'll be fine hooking up a radio from a 2001, so long as it fits.
However, the factory head unit from an Explorer will not sound better than a cheap aftermarket head unit. In fact, the after market one will sound much better.
But to hook it up, it's literally just connecting the wires in the harness to the radio and you'll be fine.
Thanks SteFin JunkYard Dog Shadetree
Take out the F150 CD player first and see if the Explorer CD player will physically fit.
I got an OEM Explorer CD player (maybe a CD/Cassette combo) at a swap meet, and was planning on installing it in a 2000 F150. Took the OEM cassette out of the F150, and noticed the backside was sloped, and not shaped like a brick like the Explorer CD player. Physically it would not fit without modification.
I did plug it in. Plugs matched. Radio worked. Did not try the CD function.
mine actually fits with little modification the slide bracket has to be reversed top to bottom bottom to top forget which but it fits in the empty hole my plugs are different the 2001 and 97 f150 are different wiring plugs with a different # of pins. I have a Chilton wiring diagram of the 2001 not for the F 150. Thanks SteFin JunkYard Dog ShadeTree
1997 Ford F Series Stereo Wiring
Constant 12V+ Green/Purple
Switched 12V+ Black/Pink
Ground Black/Green
Illumination Light Blue/Red
Dimmer n/a
Amplifier Remote Blue
Antenna Right Front
Front Speakers 6" x 8" Doors
Left Front (+) Gray/Light Blue
Left Front (-) Tan/Yellow
Right Front (+) White/Light Green
Right Front (-) Dark Green/Orange
Rear Speakers 6" x 8" Rear Corners
Left Rear (+) Orange/Light Green
Left Rear (-) Light Blue/White
Right Rear (+) Orange/Red
Right Rear (-) Brown/Pink
Thankyou so much that's perfect SteFin Junkyard Dog ShadeTree
DJ Dom you don't have the 2001 single CD player wiring color codes for an Explorer or Sport or anyone else out there. The Chilton Manual and Data on line the two sources I use are very lacking in CD/Radio wiring diagrams. DJ where did you get your information Thanks again don't mean to be wearing you out SteFin JunkYard Dog ShadeTree.
2001 Explorer:
| ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|yellow |+ |ignition harness |
| STARTER|red/lt. blue |+ |ignition harness |
| IGNITION|lt green/purple |+ |ignition harness |
| ACCESSORY|brown *1 |+ |ignition harness |
| SECOND ACCESSORY|black/green |+ |ignition harness |
| POWER LOCK|pink/yellow |*8 |driver's kick panel |
| POWER UNLOCK|pink/lt green *9 |*8 |driver's kick panel |
| LOCK MOTOR|pink/black | |driver's kick panel |
| UNLOCK MOTOR|red/orange | |driver's kick panel |
| DISARM DEFEAT|pink/orange *2 | |driver's kick panel |
| PARKING LIGHTS +|wht/blk or brown | |headlight switch or DKP |
| PARKING LIGHTS -|white/purple | |*3 |
| HEADLIGHTS|red/yellow |+ |headlight switch |
| DOOR TRIGGER|*4 |- |*4 |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|white/purple |- |driver's kick panel |
| HOOD PIN|tan/lt.green |- |driver's kick panel |
| FCTRY ALARM ARM|arms on lock *5 | | |
|FCTRY ALRM DISARM|dk. green/purple |- |driver's kick panel |
| TACHOMETER|tan/yellow | |PCM *6 |
| SPEED SENSE|gray/black |8 |PCM *6 |
| BRAKE WIRE|lt green |+ |driver's kick, brake switch |
| HORN TRIGGER|yellow/lt. green |- |steering column |
| WIPERS|wht & dk.blu/org *7 |+ |wiper motor or relay |
| LF WINDOW UP/DN|wht/blk - red |A |at motor in dr door |
| RF WINDOW UP/DN|wht/yel - tan/lt.blu|A |sw dr door or dr kick |
| LR WINDOW UP/DN|yel/lt.blu - gry/org|A |sw dr door or dr kick |
| RR WINDOW UP/DN|yel/blk - red/blk |A |sw dr door or dr kick |
| RADIO 12V|lt green/purple |+ |at radio |
| RADIO GROUND|black |- |at radio |
| RADIO SWITCH|yellow/black |+ |at radio |
| RADIO ILLUMINATE|red/black |+ |at radio |
| LF SPEAKER|org/lt grn-lt blu/wh| |at radio |
| RF SPEAKER|wht/lt grn - grn/org| |at radio |
| LR SPEAKER|tan/yel - gry/lt blu| |at radio |
| RR SPEAKER|org/red - brn/pnk | |at radio |
Thank you DjDom your top notch 10, I'm explorer parts rich so if you need something please yell at me N'ville 375-8081 Home of Country Music and Martha White Self Rising Flour. Thanks again SteFin JunkYard Dog ShadeTree.
Aha, thanks bud. But I think shipping up to Canada would be brutal. :D
If you need anything else, feel free to ask.
